So I decided to pull out the motorcycle out of its hibernation (has not been ridden for about 3 months, sat on a trickle charger). Took it for a spin and the low fuel light came on. Went to my local Shell and filled it with 93 as usual. When I started the bike it lit up the Engine light with Error Fuel code in the cluster.
I think it might be the old gas since I did not put any stabilizer in it but this has never happened before.
Any thoughts/suggestions?
Thanks in advance...
Discussion Starter #2
Bad gas in the lines, ran through for good 30 min and took it for a ride. Went away.
