Just put a new battery and stater in. Runs then the battery loses power and bike dies. No juice to start it back up. FML help any and all before I get a peddle bike.
Had a similar issue myself, brought it in enough damn near gutting the thing in my neighbors garage and coming to the conclusion it had to be grounding connections. Said screw it and let a shop rip it apart and clean them for me because it had caused enough of a head ache.
Easy. Check the stator. DIY on how to test a stator is all over YouTube. You'll have to charge the battery for a few hours so you can get the bike running again, though.
Mine had the same issue. It was the rectifier. But you need to check the stator first to make sure. It's easy to check if you have a multi-meter, volt meter. Check YouTube on how to do it. I got my rectifier on eBay for $30. It was off a salvaged Monster, so is an original Ducati part. New, the dealer wanted around $150.
