I'm less than impressed with the local dealers not being able to itemize what exactly ~$300 (Canadian) covers in the first service. I'll do what I can using a torque wrench where applicable and then likely take it to a local guy whe used to be a Ducati tech and runs his own tuning shop. Apparantly he has the official diagnostic tools for checking the belt tension and adjusting the fuel trim..
I plan on doing the following myself:
-Oil & Filter replaced
-Oil screen cleaned
-Drain plug cleaned
What esle is specified?
- Belts checked/adjusted?
- C02 checked and Fuel trim adjusted?
- What exactly is re- torqued?
Thanks!
-Oil screen cleaned
-Drain plug cleaned
Thanks!
