Hey guys (/gals),
Brake light only has one brightness when the bike is running (appears full brightness) Nothing changes when i use the rear or front brake lever.
I recently replaced the front lever, and after doing searches on this board my immediate reaction is that i must have lost the dowel, so i took the front brake lever back off, turned the key to "on" and checked the rear light with and without pressing the tiny white button on the box under the brake fluid reservoir-no difference in lighting with the button being depressed versus released.
The horn works, headlights work (low and high), turn signals work, and brake light is lit.
Any ideas??
Also, does anyone know where to get the tiny dowel that apparently fits between the front brake lever and the button that measures if the front brake is being used? i think something is supposed to be there because i dont see how the button would be depressed otherwise (although i dont think this is the lighting problem since i unmounted this and was manually pressing the button myself)
Thanks in advance for your help everyone!
Any ideas??
