Hello all,
I just purchased a S4R and found out that a needle bearing has gone bad in the transmission (found it on the oil drain plug magnet). So after talking with the Ducati dealership locally, it would be about a $2000 repair if I pulled the engine and brought it to them. Long story short, I am noticing used engines go for around $1500, but I am having trouble finding an S4R engine. I am told that other engines, such as a 999 engine, would work and I was wondering if anyone knew if this was true or not as I am new to Ducatis. Does anyone else have any recommendations? What would you do? Personally I like the idea of buying a good running engine and then being able to see my existing engine to recoup some cash. Thanks for looking.
Dan
