I took the M620 that I just bought for a ride yesterday. Rode around for about an hour yesterday. For the most part it runs great. Two issues:
1) Idle RPM is very low. Around 950 with the choke all the way out with the engine warmed up. Using a bit of choke I can get it to speed up abit. It sputters and lurches at this low RPM. It's incredibly hard to not stall, and I did end up stalling it at a stoplight while slightly leaned over, and I dropped it. Frame slider took all of the hit, thankfully. I ended up getting it onto the sidewalk and got going again, just left the choke out a bit so it wouldn't die on me. How do I raise the idle speed, or is there some other problem?
2) When I pull the clutch in, the oil warning light comes on, and when I release it, it goes off. What gives? The oil was changed by the seller about 700 miles ago. Should I change/add more oil?
