I had the same problem for my bike a while back, same bike as yours. Does it feel odd when u change gears while on the road? After a while, it just wouldn't change gears not to first or anything. Took the clutch master with the levers off & found the rubber inside it was torn.
Check ur clutch master, if that's the problem, you'll find a lot of rebuild kits online.
Good luck
