2002 620 front end on a 2006 S2R 800?
668 Views 4 Replies 4 Participants Last post by  Episteme
I need to completely rebuild the front-end of my 2006 S2R, and found this...
http://cgi.ebay.com/ebaymotors/Ducati-Monster-front-forks_W0QQitemZ110067162643QQihZ001QQcategoryZ35592QQrdZ1QQcmdZViewItem
For those in the know... would this front end off a 2002 620 fit with my bike, or do I need to keep searching?
Thanks.
I believe they should. A good way to find out is check on Ducati.com for part numbers between models. Or call a dealer and ask their parst department.
If you have a non-dark model S2R the top triple will not work with your handle bars. The non-dark S2R has the larger diameter Magura bar. So the top triple won't clamp your bar. If your S2R is a dark model it'll work with your bar.
Same forks
"If you have a non-dark model S2R the top triple will not work with your handle bars. "
Good to know - but the handle bars weren't spared in the accident either... (regardless, I have the 'dark' version).
thanks for all your comments!!! With any luck my bid will hold out and I'll be able to get one step closer to riding again this spring.
Later,
Sean
