2000 Ducati Monster 900
$4200
12,6xx miles
Yellow
Located in Chicago suburbs
  • 944cc big bore/cams/FI map installed by previous owner (reciept photo below, $2400!!)
  • 12k valve adjustment and belt replacement done 20 miles ago (receipt below)
  • Just did spring oil and filter change
  • Termi Slipons
  • Sargent seat
  • Solo cowl
  • Tail chop
  • clear alternatives integrated tail light
  • bar end mirrors
  • oberon clutch slave (stock slaves are leaky junk!)
  • motowheels clutch springs and keepers
  • billet axle plate/adjusters (stock adjusters are junk!!!)
  • always kept on a battery tender and always starts, including first try after winter
Stop sign tipover caused rear brake pedal to be slightly bent and end of front brake lever broken off. You'd be hard pressed to notice, does not affect function at all. You will not find a nicer ducati for less money. To contact me either PM through the board or email to cjvcook (at) hotmail.com
