Are the 2 pot front calipers used on the 620 and maybe others... with both pistons on one side?
I'm working a custom project and need a caliper that is slimmer than the std brembo 4 pot on the side toward the wheel. In this case spokes. So i'm looking for a model that has a "single sided" caliper so to speak.
Any info? Anybody?
Are there? Yes. 05+ 620s and S2R800s use the 2 pot, on one side calipers, mated to 300 mm rotors.
Do you need these parts, or are you looking for a bike with those stock? I didn't quite follow what you wanted/
If you need the calipers and/or rotors. I;ve got a set off an 05 620 that were pull offs for a swap to the 4 pot style.
Drop me a PM if you want the parts.
Wirespoked Sport Classic have the 2pistons also.
If pazzoducs`s problem isn`t solved already...
