Hey Guys I bought a crashed 1999 Chromo and it was missing quite a few pieces.
I am currently trying to mount the front wheel and noticed that I do not have the speedometer drive unit. I also don't have the dash and I do not plan to reinstall the factory speedometer or dash since GPS speedometers are so cheap and available.
My axle is a 20mm solid axle and after centering the wheel between the forks I believe the speedo drive dimensions should be approximately 20.2mm Inside Diameter with a 34-35mm width. My plan is to just make a new spacer on the lathe.
Thanks for any help guys!
225473
