I have tried searching but since there are 2 types of forks and such a huge disparity of oil height from year to year I am not comfortable trying an oil level from another year (range from 79mm- 132mm from the top). So my question is does anyone know what the correct oil height is for a 1997 m750 with showa(they have the 17mm nut on top) forks? also if you have the approx volume that would be great too. i know the weight is 7.5wt and the slider tubes should be 41mm for the new seals.
thanks.
