When attempting to do fork seals following instructions could not break front axle loose from bushing. For one thing did not have proper Allen wrench what size is that one? Plan get proper tools then try again...
Did you undo the lock bolts on the bottom of ONE fork leg so the nut turns while the axle is locked down ?
I did but was so tight tried to spin other side which was left tight. Now I own a 14mm Allen wrench so will try again in couple days...
