Up for grabs is an original PCS Daytona Turbo Monster, built in Daytona by PCS. 15,000 Miles on the clock. Extras include but are not limited to:
Turbo Kit: IHI Turbo (rebuilt by PCS and has 20 Miles on it), Makuni Flat Slide Carbs, Custom Exhaust, Custom Intake hood, Boost Gauge, Fuel Pump and Regulator (105BHP)
Marchesini Wheels (Aluminum)
Dyna Coils
888 Ohlins Rear Shock
Brembo Brake Master
WoodCraft Clipons
Storz Damper
Cast Iron Floating Rotors
Rear Suspension Loop Risers
DID 520 X-ring Chain
Lightened Flywheel
Custom RearSets
Intergrated LED Tail/Blinker
Corbin Seat
Carbon Front,Rear,Hugger Fender
Carbon Seat Cowl
Carbon Belt covers
This bike is truly amazing. The Flat spot between jets is to much fun, especially when the Turbo Boosts, holy hang on. Bike runs very well and is a lot of fun. Has all the right bits from this period. Tank has a couple little dings in it and the Charging system used to cook the Battery (rectifier was replaced to stop this) but the acid dripped and took some of the paint off the frame and left side engine cover. Oil has always bee Golden Spectro Synth. $6750 OBO. Easy on the low ball offers, I will just part it out if I have no interest here. Also interested in trades of 1998-2002 4 valve units (superbike). Thanks for the time.
Link to info on Turbo Kit:
http://www.duccutters.com/MikeLee-PCSkit.tpl
This is one of the four built by PCS.
High Rez shots can be seen by these links:
http://swingpad.com/db/Turbo/Dash.jpg
http://swingpad.com/db/Turbo/Front.jpg
http://swingpad.com/db/Turbo/Left.jpg
http://swingpad.com/db/Turbo/LeftFront.jpg
http://swingpad.com/db/Turbo/LeftRear.jpg
http://swingpad.com/db/Turbo/Right.jpg
http://swingpad.com/db/Turbo/RightFront.jpg
http://swingpad.com/db/Turbo/RightRear.jpg
http://swingpad.com/db/Turbo/RightTop.jpg
http://swingpad.com/db/Turbo/Tail.jpg
http://swingpad.com/db/Turbo/Top.jpg
http://swingpad.com/db/Turbo/Turbo.jpg
Discussion Starter · #2 ·
Price Drop
It has been a busy Summer and Have not been working hard at moving a few of my bikes.
Price Drop $5750.00 OBO.
Thanks.. //db
Where is this bike?
I am considering. I'd probably need to sell my Commando or pull some funds but I am considering. Sounds like a hoot.
Whoa sick!
Discussion Starter · #6 · (Edited)
All,
This bike is still available. I have decided to sell it in conjunction with another 94 monster that I have.
This other unit is a 94 900with a clear title. The bike had been down and the cases were cracked. Someone did a pretty lame job of welding the frame but it is workable. THe Tank and Fender have been painted Laguna Seca Blue.
Cases have been replaced and I have done most of the rest of the motor work but I have lost interest. This machine is mostly complete aside from the following:
Rear Sets
Horizontal Cyl. Top Valve over.
Other this this is totally complete. Wiring. MaKuni Carbs. Corbin Seat. Gauges. Oil Cooler.
Anyway. $5500 Takes both Bikes. Each has a clear title.
Bikes are located in Newport RI, 200 Miles from NYC. 100 Miles from Boston.
Thanks,
db
Images of the other bike.
http://swingpad.com/db/Turbo/IMG_0525.JPG
http://swingpad.com/db/Turbo/IMG_0526.JPG
More images of the Turbo can be found here in full rez:
http://daniel.swingpad.com/index.php/Turbo
