·I got a 4.5 rim and the stock 160 tire. I can put on a 170 on the rim right?
I'm not sure if that's true I believe the axle size changed in 2001, not '03. I have an '01 750 dark and have 25mm axles in front and back.Careful when buying a new rim. Thge 2003 use a 25mm rear axle like a S4. Prior to 2003, Monsters used a 17mm rear.
