1 - 20 of 21 Posts
· Registered
Does anyone know what LED bulb will replace the halogen bulb inside a 2019 monster? I can't believe ducati put regular non-led bulbs in the headlight on a 2019 model and would really like to replace them with a LED bulbs, but don't know what size/model to order...can anyone tell me?
Thanks!
· Registered
Thanks!
I replaced the horrible stock bulb on my 2016 M1200R with this LED - https://www.cyclopsadventuresports.com/Cyclops-100-H4-LED-headlight-bulb_p_192.html . Waaaaay better. Took some patience to fit everything in the headlight housing but it worked.
· Registered
Monster, Eljefe, will either of the ones you posted fit my 2014 1200S?
Rex
Hi Rex - I don't know for certain, but from looking at pics of both bikes, the headlight housing looks the same between the two bikes, so I expect the one I linked to would fit in your bike. I do not that is was a tight fit that took some time to get inside the housing.
· Registered
· Registered
[QUOTE="monsterluis, post: 3177226, member: 339475")
But my question is that you change the blub halogen, there is same mistake?.
Because when I was asking in the workshop, the mechanic said that is posible to change the blub but can produce a mistake on the motorbike.
[/QUOTE]
i think it may throw a code but it's not visible on the dash or does it affect anything (only visible when the dealer connects to the ECU)
1 - 20 of 21 Posts
