Do we know?
They are the same seats as the 696.
The comfort seat is taller, flatter, thicker, with less of a forward tilt.
Agreed with above. It doesn't COMPLETELY eliminate the forward slant - but with a little foam shaving it is a 100% improvement over stock - if you have the legroom for another inch or so taller seat.
Thank you!
Hi there, true about all these things but are you 100% positive it is taller? I have to say on my 696 (not sure about 1100) the standard seat and touring seat are identical in height. Different shape, consistency to foam and cover but I honestly can’t feel the difference in height. The Touring seat is definitely a great upgrade if you like your family jewels and particularly if you sit in the saddle for longer trips. I think it is one of the highest recommended upgrades to a 696 but not sure if same can be said for 1100.
I do not deny it for an 1100 I just can’t vouch for it personally as I don’t have one.
the DP Touring seat is definitely taller and more comfortable than stock on the 1100.
stock seat on the 1100 is way better than that fitted to the 696.
