I'd been questioning the accuracy of my speedometer since I bought my bike. My daily commute, which is typically 70-75mph in rush hour traffic, became 80mph+ when I'm on my bike.
So last night I was riding alongside a Honda with a digital dash and could very easily read it's speed. Sure enough, as her dash showed 42mph, mine showed 45mph. I watched this for a good mile or so, around that speed and I can confirm that my reading is 3-4mph faster than a Honda with stock wheels.
I did switch to the 14t front sprocket, but the remainder of the drivetrain is stock. I didn't think that sprocket would have changed the mph reading.... would it?
I'm going to try to check this again soon... but I wanted to see if anyone else had thoughts regarding it.
I was told by the dealer to expect my speedo to read about 8% higher than actual speed. Doing some quick math, if the Honda was accurate at 42, then adding 8% makes your speed roughly 45. For 75 mpg, 8% optimistic would make your rolling speed roughly 81 mph on the speedo.
This is consistent with what I have seen too on my Monster since I got it just over 3 weeks ago. I know there are speedo-healers, but i haven't worried about it yet really :)
I became concerned about the accuracy of my speedometer shortly after the purchase. Using a traffic laser speed measurement device I tested the speedometer at speeds in 10 mph increments from 30 mph to 70 mph. I found the speedometer to read consistently higher by about 8%. I decided to check the owners manual (when all else fails) and discovered "the dashboard receives actual speed value from the control unit and displays the value increased by 8%". So I guess that means my speedometer is accurate according to Ducati.
Discussion Starter #4
Huh? It actually says that in the manual? I wonder what that really means, and why?
Okay... so I get it that our speedos seem to read 8% high, though it seems odd that I hadn't even heard about this until today. Here's the punch line... since our speedos are too high, does anyone have a suggestion on how to lower them? :eek:
Discussion Starter #5
Google really is a miraculous thing. I found the answer myself via someone elses older post. Thanks though for everyones input!
European Union Directive 2000/7/EC set the requirements for speedometer accuracy.
There are two main requirements when tested:
1. That indicated speed is never below actual speed.
2. That indicated speed is never above 110%+4 km/h of actual speed.
For actual production motorcycles and motor tricycles, the upper limit increases to 110%+8 km/h (but remains 110%+4 km/h for mopeds).
So for a production motorcycle rolling at an actual 80 MPH, the indicated speed can't be below 80 MPH, and can't be above 92.97 MPH.
As this upper limit is 16.2% higher than actual, a built-in 8% error puts the Ducati motorcycle firmly in the middle of the legal range at highway speeds.
Just FYI... At least for Japanese bikes, this is nothing new (the speedo reading higher than actual speed). My Ninja 650R read about 10% higher than actual speed, yet the odometer was spot on accurate... The solution was to install a "Speedo-healer" inline with the ECU to remove this artificial speed increase.
As far as ways to resolve it... this is the company I am aware of, but I assume there are more :)
http://www.healtech-electronics.com/
{edit - nice info, thanks rancyc!!}
Good to see my efforts aren't wasted. :)
An easy rule-of-thumb for on-the-fly calculation of approximate actual speed is to subtract 2 MPH for every 25 MPH indicated.
