You will need to support the front end. Once that is accomplished, loosen the caliper bolts, they are the ones on the top of the caliper above the B and O in Brembo. Do NOT take off the hose going to the caliper. Once the bolts are removed, Remove the caliper off the disk and then hang the calipers off the forks with a coat hanger or something similar. Dont let them dangle and dont grab the brake!
Loosen the axle nut on the LEFT side and remove it. Under the fork legs there are two axle clamp screws on each side, loosen these as well, but do not remove. They are either Allen or Torque bolts, cannot remember which.
Use a rubber or plastic mallet to drive the axle out.
Jim
