Lets start with I weight 220 without gear.
Im looking for the suspension settings both front and rear for a 07 monster s4r with Showa suspension.
Front: Preload (in mm), rebound (amount of clicks) and compression (how many turns).
Rear: Preload (in mm or rings showing), rebound (amount of clicks) and compression (amount of click).
I don't want to max out my preload on the forks causing spring binding....well so I've read.
I know that I should install new springs all around for my weight but in the meantime I want the best/safest settings with what I got!
