I have a 02 S4, runs fantastic, teriminoli exhaust, on cold start fires right up and runs great, if it is warm out and you shut the bike down it does not want to start, acts like no spark, if I wait 15minutes it fires right up. Please help!!!!!
Could be a couple of things.
Pull the plugs and ground them to the engine and see if you have spark.
Next, check the Fuel Pressure.
IF both checks out you can check compression. If all three check out, test your temp sending unit. It could be telling the ECU that your bike is cold and it is sending too much fuel to start.
What is your MPG?
