1 - 20 of 20 Posts
2 '01 injected tanks -- one w/ ding and one I purchased from off the DML, repaired with a sub-par paint job.
1 front fender -- one red supersport style (make offer).
Titanium Termignoni Highmount Oval Cans (only the cans and mounting hardware) -- Used -- $200 obo. The new ones on it now have less than 1 tank of gas through them. If you want to talk me out of those, $850 might convince me to pull them off.
PM me if you're interested and I can email more pix.
http://washingtondc.craigslist.org/doc/mcy/222778085.html
Re: '01 M900Sie Parts (2 tanks, 2 fenders, Termi cans)
2nd in line for the used Ti high mts...still have the cf front fender?
Dani
Okay. Yeah, I still have the CF fender. Make me an offer I can't refuse?
Will the cf fender fit my '07 695? The mounting holes on mine are spaced 2.75 in., from the pic the shape/style is very similar to my stock fender.
Thanks,Dani
Believe it or not, I haven't been that close to a new Monster yet. From the looks of the pix though, you've got the same setup -- 2 bolt holes and couple rubber bands that they bolt tighten into. I'll shoot you an email with an early pic of it on my Monster later this am.
Discussion Starter · #9 ·
On it's way.
how much for the damaged tank shipped?.....will it fit an '02 S4 ? Harry
Discussion Starter · #11 ·
Not positive on that one... Anyone?
id like the pipes, but have mo means of mounting them to my stock headers...thanks though, someone should pick these up no prob. kevin
still have the CF front fender? It fit on your 01 900 right?
Discussion Starter · #14 ·
Sure do and it sure does.
pm sent on CF fender.
Quickest way to tell if a metal FI tank will fit 2000/2001 or 2002 and newer is this.
There are 4 lines that come out of the bottom for fuel (2 go to the FI system and the other 2 are drains).
On the 2000/2001 model all 4 of these lines are bent at a 90 degree angle and pointing to the back of the bike.
On the 2002 and newer 2 of the lines are bent at 90 and pointing to the back of the bike and 2 come straight out the bottom pointing towards the ground.
(the only exception to this is the 2001 S4 which uses the newer style 2002+ tank)
The other more important difference is the cut out for the airbox/battery. On the newer 2002+ tanks there's a larger cut out there to allow for more stuff under the tank, hence why the 2000/2001 tanks will not work with the newer 2002+ (immobilizer) bikes. And also why the newer 2002+ tanks hold slightly less fuel.
HTH and best of luck sellin all your stuff
I'm in line for the fender if it will fit an '05
I refer to this as small bladder bottom ('02 on up) vs. large bladder bottom ('00 & '01)....see attached examples...
and FYI...I looked at these 2 tanks last night and they are both Large Bladder Bottomed
Perfect examples.
The top one is a 2000/2001 tank as you can see all 4 lines are pointing to the hing at the back and are at 90 degrees
and the bottom (orange) one is a 2002+ tank. As 2 of the lines are bent at 90 degrees and pointing to the hinge. The other 2 are pointing straight out (the ones closer to the hinge) without any bend to them. the cut out/opening for airbox/battery is also larger on this orange tank.
Thanks for the pictures to clarify [thumbsup]
2001cromo said:
Perfect examples.
no problem!....hopefully that helps people out in the future!
1 - 20 of 20 Posts
