Hauled the monster up to Fontana today and had Dave Moss go over the bike with me. He's a pretty good suspension tuner and has setup a couple of my bikes for the track. We put the front end in a wheel chock and measured from the bottom of the rear adjuster nuts to the ground and found out it was indeed higher on the right side than it was on the left. Then we measured from the bottom rear end of each side of the swingarm and came up with the same number. That said, it means the fall he took must have moved the swingarm. I am by no means a guy who knows all there is to know about monsters. I will say this though, the boxed aluminum swingarm on a 01 monster is by no means even comparable to the swingarm on my Mille R and I would bet if you were to ride these bikes hard the rear swingarm could flex on you due to the way they are fabricated. So it is plausible that his fall could have bent his swingarm up on the side he fell on.
