Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - Nuetral
Thread: Nuetral
post #7 of (permalink) Old 04-19-2019, 05:40 PM
caferacermike
Super Moderator
caferacermike's Avatar
If using the logowear app, you need to update with every new release or performance will begin to fade and/or you might notice faster battery depletion.
You didn't say when you were getting the neutrals. I would only find them when shifting from 5th to 6th when riding at normal highway speeds. If it is after coming to a stop and attempting to shift into neutral, that method is dead wrong and should be booted from your list of habits. As mentioned in a previous post, always shift into neutral while rolling to a stop. The parts are spinning over each other and the cutaways need to align for you to pull the bits through each other. When stopped you'll be forcing the dogs and detents through the gears. There used to be a problem on earlier bikes of people breaking springs and bending shift forks from shifting into neutral at a dead stop. If you are stopped and cannot easily find neutral, rock the bike back and forth a little while pulling up on the lever.
09 Aprilia RS125 plated< NEW info> Now a 144 and back on the road!
06 Paul Smart Sport Classic NFS ever.
08 S4RS Tricolore #081 NFS ever.
The pink Monster has moved away.
97 900SS CR
72 Norton Commando 750
03 KX60 with S4R rear shock,Honda CB350F, Hodaka Ace90, 3x Yam-YGS1, Yam-CS3 200, Vespa small frame, Gilera 106, Puch Sabre, Puch 50 Boy Racer, Benelli 250, Benelli 360, Honda CB350T, and many more.
caferacermike is offline
