Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - Mushy rear brake even after bleeding.
post #2 of (permalink) Old 04-17-2019, 11:32 AM
DenverKirk
Did you removed the rear brake caliber? The bleeding nozzle is on the bottom of the caliper, the caliper has to be turned upside down for the air to come out.
Is the bike ABS?? I had the same problem here is what I did...the wrong way first and then the right way haha.
1) Removed Caliper and turned upside down
2) Bleed brake normally.
3) Replace
This worked only a little bit, and then got mushy again.
The right way
1) Ride the bike and brake hard to engage ABS
2) Turn off the bike with the kill switch but leave the key turned on (This keeps the ABS system on)
3) Replace
I repeated this process 4 times, there was a LOT of air in the lines. Back brake works great now!
DenverKirk is offline
