Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - 1200S No Rear Brake...again
post #10 of (permalink) Old 04-16-2019, 08:37 PM
Buhgaboo
Buhgaboo's Avatar
Mines still taught...but I can't stress the min mark enough...if you think that an air bubble will rise back into the reservoir if you drain it your wrong...put on a clear tube and see for yourself...if that bubble makes its way into the abs pump while engaged it gets stuck again...you can begin to see how the scenario perpetuates...
Air can be at the caliper and in the pump or in the line...pumping fluid at a steady pace clears the line ...angling the caliper up clears the caliper...ride it...engage the abs ...keep going until it's mush or annoyingly soft...repeat....keep the level up and push the fluid through the line fast enough that a rising air bubble still gets cleared...it sucks but it can be done...godspeed
Buhgaboo is offline
