The rear brake on a Ducati Monster 1200 is simply a brake light switch. I've bled, changed fluid, replaced the pads with a more aggressive compound, scuffed the rotor with a Scotch-Brite pad and I've come to understand that on flat ground at a complete stop if I clamp on the rear brake the bike will probably not begin to roll away. In the end I've learned to front-brake like a demon!
