Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - Complete S2R1000 restoration
post #5 of (permalink) Old 09-30-2018, 05:09 PM Thread Starter
Ducman7
Originally Posted by caferacermike View Post
Very fancy.
I had a frame and bits powder coated, it was done in a two part where a white was partially melted then a pink was put over that and the 2 colors were finished up. The white was to make the pink really bright.
Powder coating can be quite thick and I noticed some spots were very thick with the 2 color coating, you did 3? How did that lay down for you?
I did not do the Powdercoat myself. I had a shop in Syracuse do it called Rim Doctor. The translucent red was a little tricky for them but they ended up doing a hot coat where they had the frame in the chrome base powder warmed in the oven prior to applying the red and it came out beautiful. It is a little tricky but the frame number is still legible. I requested they only put the clear on the inside surface where the engine mounts so I could sand it down easily and have good contact for ground. I walked them through what to mask off on the other parts so I could avoid figment issues.
Sent from my iPhone using Tapatalk
Ducman7 is online now
