Re: Who rebuilds Bembo calipers
Originally Posted by petert96753
I did a dumb thing and adjusted the brake too tight . . . went off on a ride and smoked (actually burned) the brake pads . . . I have ordered new pads, but I'm worried that I damaged the seals on the pistons . . .
Hopefully they will be fine (I think they will be okay). Can you see any brake fluid leaking through around the piston.
If they are screwed up, you should be able to buy some new seals and do it yourself.
Molto brutto
