Hey man, been following your build.adventures and am about to embark on my own. Im gonna build my 1000 motor up to an 1100 highcomp with the 1100evo cams (similar to dp). So we are gonna be in a similar sort of ecu situation. My bike is an 04 m1000 so it uses the MM ecu with no provisions for o2 sensor. You ended up getting a rexxer flash right? What kinda program did they make for you?
