Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - Interesting fault ...needing help. Power failure.
post #4 of (permalink) Old 01-08-2017, 11:55 AM Thread Starter
Stickmangav
I'm getting volts getting through the fuses that get power from the 30A fuse. I don't get volts through fuses for 'Key on' or Load (From the top, fuse 1 and 3) ...this doesn't change with key on.
With the ignition unplugged I get varying voltage on the red cable on this socket (depending on wiggle from 3-8v and good voltage to small orange).
I traced that wire through the diagrams and got 12v at the origin (30A fuse), 12v at the regulator (both wires) and 12v at the 4 live fuses. I'm wondering if there is a break in connection or joining with another wire. All the other places are not affected even when I plug the ignition switch back in.
Do we know where in the loom these bits of red wire are joined so I can test them or if there are any weak points known about.
If I am barking up any wrong trees let me know.
Thanks for the response
Stickmangav is offline
