Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - Zard Monster baffle removal
SportbikeTrackGear
Old 12-29-2008, 11:16 AM   #4 (permalink)
desmoworks
Default
I believe that for most of the world the ZARD baffles aren't removable (easily at least). They are tac welded into place as well as the single bolt that comes from the underneath of the silencer end cap. You should be able to see the tack weld in there. If you grind the weld you should be able to then pull the baffles out by grabbing the inner stainless tube with a pair of pliers. The inner two tubes are the baffle while the outer one is all that will be left once you remove the baffle.
If is not tack welded all you have to do is unbolt the single bolt on the bottom of the end cap and slider the baffle out as described above.
desmoworks is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Kawasaki Forum Ducati Forum Harley Davidson Yamaha R1 BMW S1000RR Forum
Vulcan Forums Ducati Monster V-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley Forum YZF-R6 Forum Sportbike Forum
Kawasaki ZX-10R Honda 1000RR Suzuki SV Yamaha FZ8 Can Am Spyder
Kawasaki KLR 650 Honda RC51 Suzuki V-Strom Star Motorcycles Aprilia Forum
Kawasaki Versys Honda Fury Suzuki GSXR Triumph Forum KTM Forum
Kawasaki EX-500 Honda Goldwing GSX-R Forum Triumph 675 Victory Forums
