I just installed PCIII into my 695 and disconnected O2 sensor. The bike is just fine, but disconnecting the O2 sensor puts the EOBD light on, so I need to buy an O2 eliminator to correct that problem. Without disconnecting the O2 sensor Power Commander doesn't work in the lower rpm area. That is just the area I like to have more torque. I had before a Dobeck's Tfi an it works fine in a stock bike, but not with new mufflers and airfilter. Redracingparts is at the moment the only place (?) where you can buy a PCIII for 695. Unfortunally they didn't had an O2 sensor eliminator with their package.
