Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - M966 Finally Rollin !
Motorcycle.com Classifieds!
Old 07-25-2008, 03:45 AM   #1 (permalink)
MuzzMann
MuzzMann's Avatar
Default M966 Finally Rollin !
Thought you all would like to see these pics .... Finished gettin my M966 bolted together Thursday nite to get 1050 miles to MotoGP at Laguna for Friday nite (excluding the wiring I finished up in the parking lot of the motel :0) ) .... here is the list of the mods to this bike and I am sure I will leave lots out ....
95 ss900 motor completely done out by Guy at MBP to 966 ... pistons,heads , cams,crank, rods etc etc etc ... the same motors he races in Canadian Thunder series...
FCR 41 Flat slides
Fuel supply - gravity feed direct from tank - Ducati vacuum petcock & pump in the garbage
Forks - Marzocchi 58mm RAC
Triple Clamps(basic designby me expanded on & fabbed by Max Motors top fuel Harley shop)
Front Wheel - Ducati 3 spoke widened to 4.5 inches by Green's Automotive & Powder coated
Front tyre Pirelli Super Corsa 150mm
Front fender - in the garbage
Penske rear shock
Rear shock reservoir mount by MaxMotors
Rear Wheel - Ducati 5.5 - powder coated
Rear Tyre - Pirelli SuperCorsa 180mm
Brembo 18 X 20 radial brake master-front
Brembo 18 X 20 radial clutch master
Brembo radial 2 piece mono block calipers
Brembo rear caliper (master on the way)
Brake & Clutch reservoirs (in the garbage)
Earls stainless brake, clutch and oil pressure lines
Instrument panel designed by me & water jet cut c\w 95 ss tach, oil pressure guage & volt guage
Superbike bars
All switch wiring thru bars
Led front and rear signals
Aztec 8 dual headlite
Headlite mount by my buddy at Max Motors (top fuel Harley fab shop)
Battery box - by MaxMotors - all electrical components are mounted on box- nothing left under seat
Electrical - all by me - drastically shortened harness - removed all unnecessary circuits - all wiring to rear routed thru frame . this was a massive job and I will provide detailed photos if you want to see same..I have gone out of my way to make this ultra - neat and compact. Removed all bogus ducati connectors (except rectifier) and used bullet type single connectors - all are crimped and soldered - this way circuits are easier to isolate
Dyna coils mounted to frame under tank
Taylor plug wires
Rectifier mounted to frame under tank
Oil cooler - 1979 CBX
Oil cooler lines - Stainless Steel fabbed with Aeorquip fittings
Ducati Performance 50mm spaghetti header
Mufflers Reverse Megaphones - Cone Engineering - modified by Max Motors
Swing arm- Caged - 01 Monster-my design fabbed by MaxMotors nickel plated & powder coated
Tail Chop & licence plate mount by me - led signals mounted in end of frame tubes
Tail Cowl - Carbon Fibre
EK 520 chain - blue
Speedy Moto sprocket and belt covers
Speedy Moto stainless clutch springs
Evoluzione clutch slave ( anodized black by me)
Speedy Moto frame sliders
Speedy Moto fork sliders
Nicols Stainless engine bolts
Plexi Clutch cover window
All engine cover bolts and most others on bike stainless & powder coated blue
CRG mirrors
Clear Alternatives Tail light - Blue
Paint - Ducati Black with blue stripe
Engine - complete powdercoated black
Engine - MBP in Montreal
Paint by Arbor Body Shop- Tony & Andrew
Max Motors fabricator
John Valk Ducati - all ducati parts - Rusty and John are the bomb !
Speedy Moto Portland Oregon (these guys are the best!)- Chrisitian
EuroCosa - Toronto - Marco treated me like a brother
Green's Automotive wheel shop - Richmond BC
Powdercoating by Ryan at Surftech - a REAL professional !
Suspension Tuning - RMR Suspension - Rod
I had this bike on Ducati Island at Laguna MotoGP and the response was excellent. I still have lots to do as I didnt have time to strip bike down to powder coat frame ... I am doing another set of triple clamps which will double as a junction for brakes ...... etc etc .. like I said I can post pics of all these mods if you would like to see....
I also want to thank everyone here on the Monster Board for all the hookups , info and references to parts ie the Ducati Spaghetti header I bought here ..
P.S. - CHECK OUT LINK TO YOUTUBE - http://www.youtube.com/watch?v=lmydNSheX-o THIS THING GOES LIKE A SCALDED CAT AND BARKS LIKE HECK ! ( This was with only 1\3 throttle on a fresh motor !!)
Stephano
Name:	M966 & SC 1000 1.JPG
ID:	95800   Click image for larger version
Name:	M966 & SC 1000 3.JPG
ID:	95801   Click image for larger version
Name:	M966 & SC 1000 4.JPG
ID:	95802   Click image for larger version
Name:	Hottie On My Monster Laguna 1.JPG
ID:	95803   Click image for larger version
Name:	Hottie On My Monster Laguna 2.JPG
test 2
MuzzMann is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Kawasaki Forum Ducati Forum Harley Davidson Yamaha R1 BMW S1000RR Forum
Vulcan Forums Ducati Monster V-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley Forum YZF-R6 Forum Sportbike Forum
Kawasaki ZX-10R Honda 1000RR Suzuki SV Yamaha FZ8 Can Am Spyder
Kawasaki KLR 650 Honda RC51 Suzuki V-Strom Star Motorcycles Aprilia Forum
Kawasaki Versys Honda Fury Suzuki GSXR Triumph Forum KTM Forum
Kawasaki EX-500 Honda Goldwing GSX-R Forum Triumph 675 Victory Forums
