AdvanstarMotorcycleShowsSportbikeTrackGearAztec8.comMotorcycle.comSpringfield ArmorySaltLakeMotorsportsAmericanMotorcyclistAssociationCycleGear.comBikeBanditMotorcycle.com Classifieds!RentADucati.com
Old 04-15-2008, 03:51 PM   #1 (permalink)
Andyboy
Andyboy's Avatar
Default 2002 Harley Davidson Dyna Super Glide Very Custom Very fast
Posting this up for a good friend. You can ask me any questions and i will relay or you can call him at the number on the bottom, that is a daytime number.
Thanks guys
Anderw
CHASSIS
Lowered 1.5” Rear; 2.5” Front
19” RC COMPONENTS 3 Spoke Forged Chrome Front Wheel
17” x 5.5 RC COMPONENTS 3 Spoke Forged Chrome Rear Wheel with a 180 tire
530 Chain Drive with a 22 Front and 48 tooth rear sprocket
New chain
TRANSMISSION
Factory case with Andrews Billet Shafts
Baker Shift Drum and Chrome Moly Forks
Shift Dogs are “back cut” for quick shift
Heavy duty inner primary support bearings
Screamin’ Eagle clutch assembly
ENGINE
Bore 4.075”; Stroke 4” – 1710cc or 104.34ci
Crank has been cryo treated, trued, and balanced
Cases bored to accept up to 108 CI cylinders
High tensile cylinder studs
Cylinders re-sleeved with Wiseco Sleeves
30 degree domed Ross Pistons @ 13.75 to 1 Compression Ratio
Woods TW9FG Cam
Baisley 1.7 Roller Rockers @ .680 lift
S&S Gear Drive Cam System
Screamin’ Eagle Tappets
Screamin’ Eagle Forged Aluminum Rocker Arm Supports
Smith Bros. 7/16” Push Rods
Comtec MLS Head Gaskets
HEADS – REED RACING “PRO OUTLAW”
Intake ports raised ½”
2.100” Intake & 1.700” Exhaust Valves (titanium)
Hand ported Intake & Exhaust ports
Dual plugs
Compression releases in each head
Bronze seats and guides
IGNITION & CARBURETOR
Dyna TC 88 Duel Plug System Adjustable
Accel 8.8mm Wires
Bored 50mm Mikuni Carburetor
S&S “G” Custom Ported Intake Manifold
Vance & Hines VHR Pro Pipe Exhaust
MISCELLANEOUS
Chrome swing arm
Chrome Calipers
Chrome upper controls
Chrome inner & outer primary cover
Chrome cam cover
Chrome rocker boxes
Chrome transmission top & side cover
Chrome, curved Drag Specialties license plate frame
DYNO @ 137 HP @ 6,500 RPMs
DYNO @ 127 FOOT POUNDS OF TORQUE @ 4,250 RPMs
APPROXIMATELY 4,500 MILES – WILL CONFIRM
$18,000 negotiable - Call 973-347-1200 Ext 221 Ask for Sean
Call to set up a time to see the bike in person! You will NOT be disappointed!!!
Andyboy is offline   Reply With Quote
