Originally Posted by The Spider
Thanks....I've now done the degreaser and ordered springs and a paulimoto plate which replaces the individual spring caps (apparently it improves clutch feel by evenly distributing load).
Good move. its worth the bikkies. I've heard good things about the Paulimoto plate.
If I like the raw alloy look of the stock pressure plate - the degreaser has taken the grime of it - will the wire brush clean up any small pitting marks - and will wire brushing it put many scratches on it where 'crap' (technical term) will build up in the future?
Unfortunately the pitting marks wont be removed by the wire brush, unless you really heave on it. It really needs a sand/file etc to get it nice. But even with some wire brush work, clean up, prep & paint it will look a million bucks!
See here
http://www.ducatimonster.org/smf/ind...?topic=60082.0
- Chris
