Re: CRG clutch issues
Hard to say why, but the clutch isn't completely disengaging when you pull the lever. It could be that the lever is just adjusted so close to the bar that there isn't enough travel to completely disengage. Try adjusting the lever a little further out and see whether that helps. I suppose it could also just be inherent to the geometry of the lever, but if that were the case it seems like people all over would be complaining about it.
Loosing the kickstand cutout, I'm not sure about...
Modded M1k. Bent R6.
