What problem are you having?
A 1/2" air inch impact should get it while just holding the hub with your hand.
Desmo Times and others sell a clutch holding tool if that's the trouble:
Have you tried penetrating oil and heat?
You're welcome to swing by here and use my 1/2" impact if you have a way of getting the bike over here. I don't think I have a 32mm socket however... 32mm = 1.259 inches so a 1.25 inch socket should fit. I do have one of those...
