Re: New Zard exhaust on S2R1000
+1 check all the joints AND make sure those two screws going into the mufflers at the triangle brackets are tight (mine vibrated loose on my right can and so I had a leak that went unnoticed for a long time. You used high-temp gasket maker at the joints right?
