Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Profile: Mister Ducati
Mister Ducati Mister Ducati is offline
  About Me
  • About Mister Ducati
    Biography
    R&D Race Engineer
    Location
    Canada
    Interests
    Race Tuning
    Occupation
    Engine Design Engineer
    Disable Sidebar in Forum view
    Enable
  Statistics
Total Posts
General Information
  • Last Activity: 06-02-2017 10:42 PM
  • Referrals: 0
  Mentions
12-20-2016
11:45 AM - DarR mentioned Mister Ducati in post Is the difference the 1200 motor and the 1200s motor all in the ECU?
...lso be confirmed by Mister Ducati I just like separat...
  Quotes
06-02-2017
03:07 PM - Dainjah quoted Mister Ducati in post Put in my Battery in my S2R the wrong way... excitement!!
You have it wrong. For the stator...
05-31-2017
05:43 PM - Dainjah quoted Mister Ducati in post Put in my Battery in my S2R the wrong way... excitement!!
You must disconnect the yellow lea...
05-30-2017
12:55 PM - Radracer6 quoted Mister Ducati in post APS sensor?
To make things clear - The T.P.S a...
05-27-2017
07:25 PM - Dainjah quoted Mister Ducati in post Put in my Battery in my S2R the wrong way... excitement!!
The tests you have done with your ...
05-26-2017
06:20 PM - Mister Ducati quoted Sonic Duck in post Anyone running Monster 1200R with slip on exhaust without modifying ECU or fuel map?
If the motor has carbs. There ...
10:38 AM - Sonic Duck quoted Mister Ducati in post Anyone running Monster 1200R with slip on exhaust without modifying ECU or fuel map?
If a slip on exhaust does not need...
05-03-2017
09:52 PM - Sonic Duck quoted Mister Ducati in post Ducati performance handlebar bag compatibility
You may or may not know that this ...
04:57 AM - Rosso Classico quoted Mister Ducati in post Ducati performance handlebar bag compatibility
...p on handlebars ) Mister Ducati to the rescue as usu...
03-27-2017
04:22 PM - rohalloran quoted Mister Ducati in post 2003 Monster 620ie oil temp issue
Yes - to do a quick test you can r...
03-26-2017
01:49 PM - rohalloran quoted Mister Ducati in post 2003 Monster 620ie oil temp issue
...ound connection. Mister Ducati thanks. Do you think...
02-26-2017
12:55 AM - 1UglyBastard quoted Mister Ducati in post Video of 1100 cold start issue
If the starter turns over well and...
02-06-2017
06:33 PM - oldndumb quoted Mister Ducati in post M1100evo nylon fuel tank coating?
.......... NO OFFENSE TO ANYONE. ...
12-08-2016
07:38 AM - 1UglyBastard quoted Mister Ducati in post Help with M796 oil capacity
And just in case some of you do no...
11-27-2016
03:53 AM - JDIRECTORJ quoted Mister Ducati in post Headlight flickering
Ok - for the 1200 the headlight co...
10-31-2016
03:53 PM - quoted Mister Ducati in post M1200 weird noise (?)
... for this model. mister Ducati, thanks for finding ...
10-10-2016
06:26 PM - quoted Mister Ducati in post Immobilizer code - keycard missing ?
The metal tag is the "mechanical" ...
09-26-2016
06:56 PM - savaship quoted Mister Ducati in post Starting problem
The Batt Hi in the dash tells me t...
09-24-2016
08:11 AM - savaship quoted Mister Ducati in post Starting problem
Batt Hi is due to a faulty voltage...
07-31-2016
12:05 PM - Mojo66 quoted Mister Ducati in post Need to know specs measurement of Stator/ 08 Monster S4RS
The stator they are selling is obv...
07-30-2016
11:35 PM - fch99 quoted Mister Ducati in post Proper tests
