Re: Big rigs and motorcycles
Great post SC - I just wanted to make a few comments about commercial truck tires because I work FOR a retread manufacturer (it's all we do) and I work WITH many trucking/transportation companies. Commercial tire explosions are absolutely deadly - not just to other motorists, but to technicians who work on truck tires as well. However, maintenance plays a FAR greater role in whether a tire blows than whether it's original or retreaded.
Some of the largest, best maintained fleets in the world successfully run their maintenance program and retreads - even on the steer tires (UPS uses them on all of the their package vans). Most commercial jetliners run retreads on their landing gear. School buses run retreads for drive tires. However, I could give you a list of companies that I would be nervous to pass even with brand new radials on their trucks because I know from firsthand inspection that their maintenance practices are not the same as most.
Retreading is not only safe when used in a responsible maintenance program, but it's smart for consumers and the environment. Holding a CDL, I'm sure you've seen the old "if it's in the store it came by truck" type campaigns? Well, when you have 18, or more, wheel positions a reduction of $150 per wheel position also saves on transportation costs, which saves the shipper, which in turn allows good old capitalism to allow them to be more competitive (read: cheaper products).
Also, one new commercial truck tire (11R22.5 for example) takes 26 gallons of oil to manufacture. Retreading a quality worn original takes 7 gallons - a savings of 152 gallons of oil per set of drive tires. Retread manufactures also recycle all of the old tread removed during the retread process and it is used for things like playground fill, floor mats and asphalt filler.
Anyway, we get a bad rap in the retreading industry because a lot of companies either don't maintain their tires properly (inflation mostly) or try to retread casings that should not be retreaded. Personally, one way I see to reduce the amount of debris on the road is to mandate quality standards for trade trucks (trucks that are traded in by large fleets for new trucks). These vehicles usually have tires on them that are sub-standard to save money and are re-sold with these same tires.
Well, sorry for getting on a soapbox, but I'd be glad to answer any questions. I know it's frustrating - trust me I hear the stories and I've seen the explosions.
Spare
SparePart<br />Redmond, WA
