Re: Vanson Leathers complaint
I've always liked Dainese better than Vanson anyways. As I mentioned in my post here ( http://www.ducatimonster.org/smf/ind...html#msg447679 ), Vanson just doesn't seem focussed on sport riding at all, and their armor shows it.
The only problem is that I've never seen a Dainese with the same venting options Vanson has. Most Dainese are either vented/perfed, or not --They don't have zippers that allow you to choose to expose large perf panels in changing weather like some Vansons do..
Thanks for sharing your experience with Vanson. I've always wondered what that anti--Vanson remark in your sig meant.
Aftermarket: RoadRacing modified under-engine exhaust, revalved 996 forks, ProCutting open clutch, CC triple and pressure plate, 999 clipons, BMC filter, CRG-LS mirrors, PC3, Rizoma rearsets, heated grips, +2 teeth in rear gearing, Veypor VR2 computer, MBP collets, Yoyodyne slave, Galfer waves front and rear, misc CF (mostly faded). After so much work, why is it that I still can't help but consider buying other bikes?
