Re: Popped my first cherry.
Originally Posted by Norm
If you lay the intake gasket on the head & the intake, you will see that it is slightly larger that the metal faces. Just take a burr & grind away the metal until the openings are the same as the gasket.
What would be the benefit of doing this?
[img width=500 height=48]http://www.ducatimonster.org/ImageFolio3_files/gallery/DML_Member_Bikes/Group_05/DucatiMichael.JPG[/img]<br /><br />Grand Rapids, Michigan<br /><br />"Go Forth and Modify"
