Ducati Monster Forums: Ducati Monster Motorcycle Forum - View Single Post - Popped my first cherry. FINISHED PHOTOS ADDED.
Motorcycle.com Classifieds!
Old 03-18-2005, 10:08 AM   #6 (permalink)
Michael_Gannon
Send a message via AIM to Michael_Gannon
Default Re: Popped my first cherry.
Originally Posted by Norm
All the pulleys come off with that special nut tool. You can make one if you're handy.
Thanks for the in depth response. I consider myself handy but I don't have a welder so I don't know if that would limit my options.
There are timing marks on the cases to help you line up the pulleys when you reassemble. Assuming you're not changing pistons, yes, you should lightly wire brush the black goop off.
That's good to know about the timing marks although I'll probably have to address this issue further when I actually get to the reassemble stage. No I'm not changing pistons. Do I need to be really worried about crud falling off and getting down into the engine if I use a wire brush to clean the pistons?
When you reassemble, rough up the intake manifolds to a uniform texture, remove any seams, cut the vacuum bolts flush, & use a gasket to port match the intakes & heads.
Don't let my ambition fool you. I'm very new when it comes to this stuff. What exactly is the intake manifold? What seams are you talking about? Where are the vacuum bolts? "Use a gasket to port match the intakes & heads" ????
[img width=500 height=48]http://www.ducatimonster.org/ImageFolio3_files/gallery/DML_Member_Bikes/Group_05/DucatiMichael.JPG[/img]<br /><br />Grand Rapids, Michigan<br /><br />&quot;Go Forth and Modify&quot;
Michael_Gannon is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Kawasaki Forum Ducati Forum Harley Davidson Yamaha R1 BMW S1000RR Forum
Vulcan Forums Ducati Monster V-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley Forum YZF-R6 Forum Sportbike Forum
Kawasaki ZX-10R Honda 1000RR Suzuki SV Yamaha FZ8 Can Am Spyder
Kawasaki KLR 650 Honda RC51 Suzuki V-Strom Star Motorcycles Aprilia Forum
Kawasaki Versys Honda Fury Suzuki GSXR Triumph Forum KTM Forum
Kawasaki EX-500 Honda Goldwing GSX-R Forum Triumph 675 Victory Forums
